https://jira.xxx.com/rest/servicedeskapi/request/
is there a way we can use this url to filter JIRA Service Desks issues from a specific project?
thanks,
Dear @Samuel Donadelli,
you can simply use any REST URL within your browser. The returned data will be in JSON. The request above is for Jira Service Desk, only. You can also use the REST API calls for Jira Server. The URL would look like
https://jira.xxx.com/rest/api/latest/search?jql=project=MYPROJECT
So long
Thomas
Hi Thomas, thanks for your answer.
I noticed that in the output of this restAPI we have many customfields that shows "null" values.
Would you know a manner we obtain only fields with contents (no null values) ?
thanks , Samuel
the REST API returns all available custom fields, even if they are empty. To get more information from one issue, you can play with the parameter "expand" (See the API Doc) to retreive more. But be aware, this can take longer and slow down Jira.
So long
Thomas
