×I tried following JQL search that is working :
project = XXXX and type = YYYY and component = "[ART] toto"
but I would like to seach all issues that has component field that contains "toto" string.
for instance :
project = XXXX and type = YYYY and component ~ "toto"
but then I have this error :
"The operator '~' is not supported by the 'component' field."
what would be the solution to search issues with a field that has one string inside its different values ?
Hi @ribas ,
As Robert mentioned, you might need to utilize a third-party app for this case.
For instance, if you are using Adaptavist Scriptrunner in your Data Center environment, you can leverage the componentMatch function. This function allows you to search for components that meet specific patterns.
Example:
component in componentMatch("^web.*")
This query would identify all issues related to web components.
You can find more details here -> Match Functions - Adaptavist Documentation
If you find this suggestion helpful, please accept the answer so that others can benefit as well!
Best regards,
Gaurav
thank it worked with
componentMatch
it seems this function is available without JQL booster pack.
I don't understand why...
but what if the field is not component but a user defined field ?
In case it is any other user-defined field, you can use below function.
issueFieldMatch (subquery, fieldname, regexp)
Example.
issueFunction in issueFieldMatch("project = JRA", "description", "ABC\\d{4}")
Notes by app vendor:
- You need to double the backslashes.
- The function searches for the reg exp anywhere within the field. To match the entirety of the field, use ^ and $, e.g.
^ABC\\d{4}$.
All such match functions are available at this page -> match-functions
BR,
Gaurav
Hi @ribas
to the best of my knowledge, components don't support partial text matching in native JQL. You'll need extra tooling for this.
For a native solution, I could imagine to use Jira Automation to sync component name(s) into a custom field of type single-line text, and then search on the custom field. Obviously, this will complicate your setup quite a bit.
Alternatively, you can always export your data and perform the search e.g. in Excel.
Lastly, if you're open to solutions from the Atlassian Marketplace, you'll have a number of options available. E.g., there's a number of apps that extend JQL, or provide their own, more powerful search mechanisms. I'll add more information below.
Hope this helps,
Best,
Hannes
... and to expand on my last point: If you're open to solutions from the Atlassian Marketplace, your use case would be easy to solve using the app that my team and I are working on: JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of advanced features, including support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting - as well as the ability to filter any issue field via text search.
This is how it looks in action:
(For more advanced use cases, you can also use regular expressions.) Once you've narrowed down your list of issues, you can work on your issues directly in JXL, trigger various operations in Jira, or export your issues with just one click.
Any questions just let me know!
Hi @ribas , unfortunately wildcard search is not natively supported by Jira on Data Centre.
You will need to install a 3rd party app from the Atlassian Marketplace to enable a wildcard search. Here are a few that I was able to find quickly:
Hope that helps!
Robert
