hello,
user is reporting that they cannot see the option log work which is present is another.
how can i copy the option from the project?
Cross check the Field Configurations and Screen Schemnes of both JIRA projects.
The project where you don't see Log Work might be using a different field/screen configuraitons.
Also, the user should be having "Work On Issues" permission on the project.
