  • Community
  • Q&A
  • Jira
  • Questions
  • how do I import projects into JIRA Portfolio (from JIRA) after the initial portfolio is created and the scope is defined?
steve tolson July 31, 2016
When I first create a plan in JIRA Portfolio I see that your're able to define the scope from JIRA. But, after the initial plan is create, I don't see how you are able to get new stories into JIRA Portfolio from the JIRA project it is mapped to? How is this done?
Martin Suntinger
July 31, 2016
Hey @steve tolson, as mentioned by @Steven Behnke already, once a live plan is connected, there is no need to import at all anymore - new stories will show up automatically as you refresh the page or re-calculate the plan!
If you need to add entirely new sources of data (e.g. additional projects, or filters), or you want to re-include issues you have explicitly excluded before, you can do that via the plan configuration > Issue Sources > Edit sources which takes you through a wizard similar to the initial plan creation.
Steven F Behnke
July 31, 2016
Are you referring to Portfolio Live plans?
If so, you don't need to import – The scope defines the issues that are allowed into the Plan.
