how do I link a field of pickers with multiple issues to tasks?
Evgeniy April 16, 2021
Good afternoon. It is not possible to implement a script that, when creating a request on a custom portal, creates a certain relationship based on the completed tasks from the multiple issue pikers field.
The result of what I tried, alas, does not work.
import com.atlassian.jira.issue.link.IssueLinkTypeManager
final def linkName = "мероприятия"
def issueLinkTypeManager = ComponentAccessor.getComponent(IssueLinkTypeManager)
def customField = ComponentAccessor.customFieldManager.getCustomFieldObject(14020)
def linkType = issueLinkTypeManager.issueLinkTypes.find{ it.name == linkName }
def story = issue.getCustomFieldValue(customField) as Issue
if (story) {
def user = ComponentAccessor.jiraAuthenticationContext.loggedInUser
ComponentAccessor.issueLinkManager.createIssueLink(story.id, issue.id, linkType.id, 0L, user)
Max Lim _ScriptRunner_
April 18, 2021 edited
Your request is not exactly clear but from what I read on your script. You are probably using a post function on a create transition.
1. Have you moved your post function order to be after "Creates the issue originally."?
2. You might want to use doAfterCreate {} closure too if you are using "clone an issue, and links". Try:
doAfterCreate = {
if (story) {
Evgeniy April 18, 2021
I beg your pardon for the translator.
1) I want to specify tasks when creating a request on the portal.
The multiple issue pikers field helped me with this.
2) At the creation stage, I need the tasks in this field (all) to be associated with the task being created. (with the link name I need)
At the moment, the script from my example does not work. I can’t tell you what the problem is. I would be very grateful if you can help.
I am a beginner in script runner.
April 18, 2021
1. Since you are using a multiple issue picker field, the return type of the field is a list of Issue objects, so please try:
def stories = issue.getCustomFieldValue(customField) as List<Issue>
if (stories) {
stories.each {
ComponentAccessor.issueLinkManager.createIssueLink(it.id, issue.id, linkType.id, 0L, user)
2. Can you confirm that you have moved your post function to be after "Creates the issue originally."?
3. If above doesn't work, please provide more details:
  • Are you using "Custom script post-function"? or other ScriptRunner's built-in post-functions (end with "[ScriptRunner]"):
  • Can you provide screenshots of your configurations?
Like Evgeniy likes this
Evgeniy April 19, 2021
Thank you very much! Everything worked out.
Tell me please. How can I delete the value in the picker field with multiple issues after filling in the links?
One more thing, in the script we choose the Name of the connection, and if I need to specify a specific outgoing or incoming connection ?
April 19, 2021
You can set the field to null and update the database like so:
issue.setCustomFieldValue(customField, null)
ComponentAccessor.getIssueManager().updateIssue(ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser(), issue, EventDispatchOption.ISSUE_UPDATED, true)
In the script we choose the Name of the connection, and if I need to specify a specific outgoing or incoming connection ?
You can specify the link as outward or inward by changing the order of arguments, like so:
// or
ComponentAccessor.issueLinkManager.createIssueLink(issue.id, it.id, linkType.id, 0L, user)
 I hope this helps!
Added the code to the end. Returns an error when resetting values.
April 19, 2021
I am sorry, you need to import the appropriate class:
Evgeniy April 20, 2021
Thank you very much! Everything is working.
Special thanks for your patience and explanation.
I really appreciate it.
April 20, 2021
You are most welcomed. Please accept my answer for future reference.
