×I have Jira working at example.com:8090. However, I'd like to set it up at jira.example.com.
I've tried a basic VirtualHosts addition:
<VirtualHost 72.3.139.6:80>
ServerName jira.example.com
ProxyPass / http://localhost:8090/<br< a=""> /> ProxyPassReverse / http://localhost:8090/<br< a=""> /> <Proxy http://localhost:8090/><br< a=""> /> Order deny,allow
Allow from all
</Proxy>
ErrorLog logs/requests.example.com-error_log
CustomLog logs/requests.example.com-access_log common
</VirtualHost>
which gets me most of the way there. I can see the login page at jira.example.com, but I get this error message:
Dashboard Diagnostics: Mismatched URL Hostname
JIRA is reporting that it is running on the hostname 'localhost', which does not match the hostname used to run these diagnostics, 'requests.lmpartnership.org'. This is known to cause JIRA to construct URLs using the incorrect hostname, which will result in errors in the dashboard, among other issues.
The most common cause of this is the use of a reverse-proxy HTTP server (often Apache or IIS) in front of the application server running JIRA. While this configuration is supported, some additional setup might be necessary in order to ensure that JIRA detects the correct hostname.
The following articles describe the issue and the steps you should take to ensure that your web server and app server are configured correctly:
Gadgets do not display correctly after upgrade to JIRA 4.0
http://confluence.atlassian.com/display/JIRAKB/Gadgets+do+not+display+correctly+after+upgrade+to+JIRA+4.0<br< a=""> />
Integrating JIRA with Apache
http://confluence.atlassian.com/display/JIRA/Integrating+JIRA+with+Apache<br< a=""> />
Integrating JIRA with Apache using SSL
http://confluence.atlassian.com/display/JIRA/Integrating+JIRA+with+Apache+using+SSL<br< a=""> />
If you believe this diagnosis is in error, or you have any other questions, please contact Atlassian Support.
I've looked at all those pages, but none of them seem to help.
I also tried the advice on this page:
http://confluence.atlassian.com/display/CONF31/Using+Apache+with+virtual+hosts+and+mod_proxy
But that gives me a 502 Proxy Error:
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET /.
Reason: DNS lookup failure for: jira-app-server.internal.example.com
How do I set this up so I don't have the mismatched hostname issue?
I had the same problem that you did and here's how I fixed it:
<VirtualHost bugs.mysite.com:80>
ServerName bugs.mysite.com
ProxyRequests Off
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
ProxyPass / http://localhost:8080/
ProxyPassReverse / http://localhost:8080/
</VirtualHost>
Add the following:<Server port="8005" shutdown="SHUTDOWN"><Service name="Catalina"><Connector port="8080"proxyName="bugs.mysite.com" proxyPort="80" />
<Service name="Catalina"><Connector port="8080"maxThreads="150"minSpareThreads="25"maxSpareThreads="75"connectionTimeout="20000"enableLookups="false"maxHttpHeaderSize="8192"protocol="HTTP/1.1"useBodyEncodingForURI="true"redirectPort="8443"acceptCount="100"disableUploadTimeout="true"proxyName="bugs.domain.com" proxyPort="80"/>
BTW this was base 4.4 Jira install.
This redirect all my subdomains to JIRA :( how i cant prevent this issue?
I use jira.company.net and wiki.company.net for our installation of jira/confluence. End users talk to apache on port 80 which handles all the work of proxying to JIRA running on port 8181
Here's a simplified version of the VirtualHost for JIRA, you'll need to substitute your own IPs and ports. Once you get this working you can start getting creative and adding additional optimizations via mod_rewrite or maybe even google's mod_pagespeed.
<VirtualHost 10.x.x.x:80>
ServerName jira.company.net
ServerAlias jira
DocumentRoot /opt/jira
ErrorLog /opt/jira/apache/logs/jira-error_log
CustomLog /opt/jira/apache/logs/jira-access_log common
RewriteEngine on
# if the maintenance file exists, redirect to the "maintenance" url
RewriteCond %{DOCUMENT_ROOT}/maintenance -f
RewriteRule (.*) http://statichtml.company.net/jira/ [P,L]
# otherwise act as a proxy to jira which is running on port 8181
ProxyPreserveHost on
ProxyPass / http://10.x.x.x:8181/<br< a=""> /> ProxyPassReverse / http://10.x.x.x:8181/<br< a=""> /></VirtualHost>
Hi Alex,
Thanks for providing your VirtualHost example - much appreciated.
Still not quite working for me, though -
when I try going to jira.example.com, I get redirected to
example.com/secure/Dashboard.jspa
with a 404 error.
Any suggestions?
Thanks again!
I just installed jira in my server as a subdomain : jira.example.com
I followed those topic's instructions which help !
Everything went fine but the home widgets did not rendered properly and I'm getting this hint on homepage :
We've detected a potential problem with JIRA's Dashboard configuration.
JIRA is reporting that it is running on the port '8080', which does not match the hostname used to run these diagnostics, '80'. This is known to cause JIRA to construct URLs using the incorrect port, which will result in errors in the dashboard, among other issues.
The most common cause of this is the use of a reverse-proxy HTTP server (often Apache or IIS) in front of the application server running JIRA. While this configuration is supported, some additional setup might be necessary in order to ensure that JIRA detects the correct port.
I dont't really understand what to do and I'd appreciate a little help :)
Thank you !
Hi Kiminca,
Can you check the following:
1. Serverbase url- Admin > general config-- Ensure that it references the right place.
2. Connector element in the server.xml (or jira.xml if you're using an ear/war). Make sure that you've defined the proxyHost and proxyPort attributes as per http://confluence.atlassian.com/display/JIRA/Integrating+JIRA+with+Apache. Might help me out if you could post the connector element.
Hi Tim,
Thanks for the quick reply!
Server Base URL in Admin is http://example.com:8090 .
I had not added the proxyHost and proxyPort attributes when I posted this question. I have now. Here's the connector info:
<Connector port="8090"
maxThreads="150"
[snip]
protocol="HTTP/1.1"
redirectPort="8443"
acceptCount="100"
proxyName="example.com" proxyPort="80"
I restarted Jira and the server, but I'm still getting the Proxy Error.
(By the way, the 600 char limit makes it hard to provide this info.)
Yikes - sorry about the formatting of this question! I've tried to clean it up a bit. I'm working on trying to work out the bugs in editing here in Answers.
As for your question, I'll hunt for a colleague who's better at networking than I am...
Hi team, can I add a subdomain on Hosted Jira server ?
Jira Server is not hosted on any Cloud Platform. it's a normal Linux Server.
