×I need to set up a notification to go to a specific team member when an issue/story is moved to owner review in the work flow. How do i set that up?
Here are two links that may be of use to you depending on how you want to do this. First, the general directions are here:
https://confluence.atlassian.com/display/JIRA063/Creating+a+Notification+Scheme
If you want to create a custom event, you'll create the event, add it to the notification scheme, then add it to the workflow:
https://confluence.atlassian.com/display/JIRA063/Adding+a+custom+event
You can expand the notification recipients if you want beyond the single user later perhaps adding a group of users if you wish.
Best wishes!
Learn more
