how do i get all the jobs i have worked on, programmer field or history
Xin Ying Phee
March 11, 2020
Hi
I want to get a report on how many jobs i have worked.
I usually get assigned a job under programmer but when I am finished with the job, I assign it back so my name is not in the assigned field.
The only place will be under history.
Is there a way to search for that?
Bronagh Quinn
Using JQL you can search for this using WAS instead of IS
" Assignee was Programmer " will return tickets where programmer was ever the assignee on the ticket.
Hope that helps
Bronagh
Zoryana Bohutska _SaaSJet_
Hi @Xin Ying Phee
Also, you can consider the add-on Issue History. It let you view the log of all activity at issues that you or other reporter had made. For example, change status, summary, description of issue or assignee etc.
Regards
