how to Automate workflow transitions based on Customfield?
Prasad Netaji N
  • I have created one  workflow with several statuses.
  • I have added screen with having custom filed dropdown values to one transition.
  • if i choose one value from custom field i want to automatically move to another status.Please help me what all the posible ways are theire to solve this problem.
Jack Brickey
basically you need a “listener” that triggers on the custom field being updated. Here is a thread that might lead you in the right direction.
elvir.dzeladin
January 22, 2020
This can be done easily with automation for jira:
https://marketplace.atlassian.com/apps/1215460/automation-for-jira?hosting=cloud&tab=overview
Good luck and let me know if you need help.
Prasad Netaji N
I want to do this with script.Please help me
elvir.dzeladin
January 22, 2020
What do you mean by "script" ?
Do you mean script runner ?
That's not a basic feature from jira, you are gonna need a plugin
Prasad Netaji N
I have script runner plugin.Is it posible to solve above problem?by using post function in jira workflow is posible but i dont no how to do that.Help me
elvir.dzeladin
January 22, 2020
Sorry I am not good enough in scripting. Hope somebody else will help.
Prasad Netaji N
Ok
