Hi All,
I need to interate holiday calender with my JIRA instance. ex: week ends, special company holidays. I'm using JIRA 4.3.2 version. Could you help me pls.
HesH
Hi Hesh, I notice there is two Calendar plugins available in Atlassian Marketplace. You could refer to the following pages :
I hope it helps :). Good luck. Regards, John.
"Team Calendars JIRA Integration" only works if you have Confluence, right?
Looks like it's functionality is with Confluence, not JIRA.
Yes, that's correct. The only calendar you have with JIRA alone is the JIRA calendar, which just maps issues and it's due dates to a calendar, i.e. you will have to create an issue for each holiday etc.
