Hello Team,
Our requirement is whenever issue is assigned to some one in new/To do status automatically to collaborators custom filed
we are implemented to each and every transitions to add post function Copy Value From Other Field (JSU) it is working fine whenever move to other status only assignee will be added to collaborators field but not in initial status not happened automatically untill unless move the transition to other status we applied post function while create to new also
So we want to be happen in the initial status also this should be done automatically when assignee changed or updated
please suggest how to fix it if any possible through scripting we using script runner plugin also
we are using Jira-7.9.2 standalone server application
Register today
