how to add plugin logging to Logging and Profiling permanenently
Chandrasekar Ranganathan Parimala
May 4, 2020 edited
Hi All,
I have a plugin for which I need to add the logging to 'Logging and Profiling' Screen permanently. I know we can add it manually our package 'com.yourcompany.plugin".
I tried to implement  LifecycleAware to try to do it on startup but I couldn't find the package to do it.
how to add your plugin’s log to a separate log file inside the project.
Earl McCutcheon
May 5, 2020
Hello @Chandrasekar Ranganathan Parimala ,
Thanks for reaching out and to permanently add in a logging package you can do so by modifying the web.xml file as detailed in the "Logging and profiling" documentation under the section:
  • permanently — your change to the logging level will persist, even after you restart Jira.
Earl
