×Hi,
I have created few custom fields as per the requirement. Now I would like to show some tool tip or similar function as a help function for that particular custom field.
is it possible to create it ?
Nayan
I'll clarify my question more.
what I have is a custom field which contains list of values.
Now what I want is to have a tool tip for each of the possible list values.
Nayan
You could do it by using jQuery. JQuery can be used in description field of your custom field.
<script ....>
// get values
// for each value add a hint
</script>
