I want to add “Closed” and “On Hold” status transitions from all the states of Workflow, when Ticket Type/Category which is a cascading field where the values are selected from drop down values where first value is “Environment Support” and second value say "xyz...". So the value of Ticket Type/Category is "Environment Support xyz...". But I do not see any operator that can compare the string which is made up of two values, based on which I can add or remove “Closed” and “On Hold” workflow status transitions. The only available String comparison operators are == and !=
Cascade fields are not strings, that's why the operators do not work. The next question is what plugin you are using to create your conditions, because the standard ones don't handle custom fields, and the ones I've used (and written) to provide conditions based on custom fields ask you what options you want with a select list - they don't offer you any comparisons.
To be more specific, can you please tell me Problem: how can I configure the workflow status transition based on any cascade field that gets value from more than one list components. Currently we can configure the workflow status transition based on a field which gets value from a single text field component, by using the comparison operators >=,<=,==,!= etc. but it doesn't work for Cascade type fields.
Do you mean Jira? Not sourcetree as you label says?
AI-curious? This series walks you through building Rovo Agents step by step, no matter your experience level. Multiple workshops available throughout October and November!
Register now
