how to bulk export of all test cases in xls or csv
jvinodh November 5, 2013
We can export a single test case to csv, I need to know if we can export in bulk (all TEST cases into one file meaning not 1 at a time) AND be able to export test cases with their results. Please let me know if this is possible?
Thanks in advance!!
Emily Schneider
November 5, 2013
Hi Vinodh,
Yes this is possible. What you can do is use the Search Test Executions screen to search for all the test cases you want to export. Once you find them all you can export them out including all of their results.
https://zephyrdocs.atlassian.net/wiki/display/ZTD/Search+Test+Executions
Kind Regards,
Emily
Hi Emily,
Thanks for the quick response, I already did the search but didnt get any result. Also does search query will run in 1.7 version or the latest version, coz we are using 1.7 version of zephyr.
Could you please send me a sample query that would export all fields of TEST cases in a project and export it to xls or csv file?
Any help will be much appreciated :)
Vinodh
Like Barbara Friedman likes this
shikha Goswami June 1, 2021
how to export issues from jita to excel with test steps and test data
Levente Szabo _Midori_
Hey @shikha Goswami
Try Better Excel Exporter, as it's integrated with Zephyr and can export your test steps, executions, and other test data. See some examples >>>
shikha Goswami June 3, 2021
@Levente Szabo _Midori_ thanks ..can u plz help me out in one more thing ..like i want to cascade select list in jira from excel ,can u plz help me out in this ..it will be a  great help for me
Dee Colton
January 15, 2017
I have the same query above however my test has not been executed.  I need to export a bulk of test cases to into a CSV.  Also, when in Test Cycle, I know I can click on "Export Tests" for each Test Case but not bulk.  How can this be function be performed for a bulk list of test cases.  Last, I have tried as an example to Export Test in all three formats and only the headers are appearing.  Is there a setting in the backend that I am missing?  Help.
Emily Schneider
November 5, 2013
Hi Vinodh,
In order to get this feature you will need to upgrade to Zephyr for JIRA 2.0.1.1426. It is only on this version that you can export out how it is you are seeking. There are already example queries built into Zephyr for JIRA 2.0.1.1426 for you to use as well. Also, here is a list of keywords so you can do a ZQL query:
https://zephyrdocs.atlassian.net/wiki/display/ZTD/ZQL+Reference
We are also going to be releasing Zephyr for JIRA 2.1 in about a week. Zephyr for JIRA 2.1 will be fully compatible with JIRA 6.1.
Kind Regards,
Emily
