how to calculate the sum of 2 custom fields to the third custom field
Andrews September 3, 2020
I want to display sum of two number fields to third number field.
ex: 1 Support Count CRM(2.0) = 510
      2 Support Count CRM(Old) = 10
      3 Support Count CRM(New) = 4
Calculate the sum of 2 custom fields (2+3) to the third custom field (1)
  • 1= 2+3
  • 510 = 10+4
  • 524
@Mathis Hellensberg - Where do i add the script apart from the script field??
Mathis Hellensberg
September 3, 2020
First you create the script field and place it on whatever screen you need it on, then go to manage apps and you'll be able to find it under Scriptrunner > Fields :)
Mathis Hellensberg
September 3, 2020
Assuming they are all 'Number Fields' this approach should work.
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.ModifiedValue
def customFieldManager = ComponentAccessor.customFieldManager
def issueManager = ComponentAccessor.issueManager
def issue = issueManager.getIssueObject("ITSD-57")
def number1Value = customFieldManager.getCustomFieldObjectsByName("Number 1")[0].getValue(issue)
def number2Value = customFieldManager.getCustomFieldObjectsByName("Number 2")[0].getValue(issue)
def number3Field = customFieldManager.getCustomFieldObjectsByName("Number 3")[0]
def number3Value = number1Value + number2Value
number3Field.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(number3Field), number3Value), new DefaultIssueChangeHolder())
@Mathis Hellensberg - So again do i need to create any script field?
if script field not required then where do i update the script?
Mathis Hellensberg
September 3, 2020
You could very well do it in a scriptet field :)
