how to capture the value of updated custom field when specific value added or removed
J Manas Kumar
HI My Basic requirement is , I have parent issue and 2 child issues.
Ex:- parent custom field= 1,2,3,4   . child field 1 = 1,2,3,4   .Child field 2 = 1,2,3
what i want is when ever i will remove any value from child issue it will check that if the removed value is present in other child issues or not , if not it can remove the value from parent issue, if the value is present in other child issues then no need to change values in parent issue.
i am able to do the first scenario(when removed value from one child issue is present in other child issue, so dont delete in parent level).
but for the second conition i am facing issues, as i am using removeAll() method its removing all unique one , not the specific element.
Can anyone help on this ? Any help will be appreciated.
import com.atlassian.jira.issue.link.IssueLink
import com.atlassian.jira.bc.issue.IssueService
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.issue.customfields.option.Option
import com.atlassian.jira.util.ImportUtils
import com.atlassian.jira.issue.index.IssueIndexingService
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.issue.search.SearchResults
import org.apache.log4j.Logger
import org.apache.log4j.Level ;
log.setLevel(Level.DEBUG) ;
Issue epicIssue = event.issue
String issuetype = epicIssue.getIssueType().getName()
if(issuetype == "Epic"){
if (event?.getChangeLog()?.getRelated("ChildChangeItem")?.find { it.field == "Impacted Application/s" }) {
def changeItem = event?.getChangeLog()?.getRelated("ChildChangeItem")?.find { it.field == "Impacted Application/s" }
String[] newValue = changeItem.get("newstring").toString().split(';')
String[] oldValue = changeItem.get("oldstring").toString().split(';')
log.debug("New Value: "+newValue)
log.debug("Old Value: "+oldValue)
//Split and get array of entries per CSI
if( (oldValue[0] == 'null') || newValue.size() < oldValue.size()){
def ImpactedAppField = customFieldManager.getCustomFieldObjectByName("Impacted Application/s")
String ImpactedAppValue = epicIssue.getCustomFieldValue(ImpactedAppField)
log.debug("Value in Impacted App field is: "+ImpactedAppValue)
log.debug("Value in Event is: "+ event?.getChangeLog()?.getRelated("ChildChangeItem")?.find { it.field == "Impacted Application/s" })
def change = event?.getChangeLog()?.getRelated("ChildChangeItem")?.find { it.field == "Impacted Application/s" }
log.debug("Value In CHANGE is : ///////" + change)
def cf = customFieldManager.getCustomFieldObjectByName("Parent Link")
def parentValue = epicIssue.getCustomFieldValue(cf)
if(parentValue != null){
// log.debug("parent Value is: "+parentValue)
def issueManager = ComponentAccessor.getIssueManager() ;
Issue PlanviewIssue = issueManager.getIssueObject("" + parentValue);
log.debug("Planview Issue is: "+PlanviewIssue)
String planviewImpactedApp = PlanviewIssue.getCustomFieldValue(ImpactedAppField)
log.debug("Planview Impacted Apps are: "+planviewImpactedApp)
if(planviewImpactedApp != null){
def userManager = ComponentAccessor.getUserManager()
ApplicationUser admin = userManager.getUserByName("INT_JIRA")
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser.class)
def searchService = ComponentAccessor.getComponent(SearchService)
def searchProvider = ComponentAccessor.getComponent(SearchProvider.class)
String[] impacted = ImpactedAppValue.split("\\s*[;]\\s*");
List<String> fixedLenghtList1 = Arrays.asList(impacted);
ArrayList<String> listOfEpicValues = new ArrayList<String>(fixedLenghtList1);
log.info "Printing listOfEpicValues For Epic Issuee Value : --" + listOfEpicValues
String[] planViewImpact = planviewImpactedApp.split("\\s*[;]\\s*");
List<String> fixedLenghtList = Arrays.asList(planViewImpact);
ArrayList<String> listOfPlanViewValues = new ArrayList<String>(fixedLenghtList);
ArrayList<String> newList = new ArrayList<String>(fixedLenghtList);
log.debug("Printing New List Parent --- before Subtract ---->>>>" + newList)
if(planviewImpactedApp != ImpactedAppValue){
listOfPlanViewValues.removeAll(listOfEpicValues)
log.debug("Printing listOfPlanViewValues after Subtract --->>>>" + listOfPlanViewValues)
ArrayList<String> duplicatevalues = new ArrayList<String>();
ArrayList<String> uniquevalues = new ArrayList<String>();
for (String item : listOfEpicValues) {
if (listOfPlanViewValues.contains(item)) {
duplicatevalues.add(item);
log.debug("Printing duplicatevalues after --->>>>" + duplicatevalues)
} else {
uniquevalues.add(item);
log.debug("Printing uniquevalues after --->>>>" + uniquevalues)
def removedAppId = listOfPlanViewValues.toString().replace("[", "").replace("]", "");
log.debug("Printing removedAppId after --->>>>" + removedAppId)
def query = "\"Parent Link\" = ${PlanviewIssue.key} AND issuetype = Epic"
SearchService.ParseResult parseResult = searchService.parseQuery(admin, query)
def searchResult = searchService.search(admin, parseResult.getQuery(), PagerFilter.getUnlimitedFilter())
def issue1 = searchResult.getResults()
log.debug("Getting Issues1 values :--------"+issue1)
searchResult.getResults().each {documentIssue ->
def query2 = "\"Parent Link\" = ${PlanviewIssue.key} AND issuetype = Epic AND 'Impacted Application/s' ~ '"+removedAppId+"'"
SearchService.ParseResult parseResult1 = searchService.parseQuery(admin, query2)
def result = searchService.search(admin, parseResult1.getQuery(), PagerFilter.getUnlimitedFilter())
def issue2 = result.getResults()
log.debug("Getting Issues2 values :--------"+issue2)
/*Here i am checking the value which has been deleted from Epic & is it present in any other epic or not */
if(result.getTotal()>0){
log.debug("it is coming to If Block....-->>>")
// do nothing
}else{
newList.removeAll(Collections.singleton(removedAppId));
for(String str: listOfPlanViewValues){
if(str == removedAppId){
newList.remove(removedAppId)
log.debug("Prinitng newList inside esle --> for --> if -->....-->>>" + newList)
// newList.removeAll(listOfPlanViewValues)
log.debug("it is coming to Else Block....-->>>")
def planviewValues = newList as String
log.debug("Printing PlanView Valuessssssss :-->>>>>>>>" + planviewValues)
String SEPARATOR = ";";
StringBuilder csvBuilder = new StringBuilder();
for(String app : newList){
csvBuilder.append(app);
csvBuilder.append(SEPARATOR);
String csv = csvBuilder.toString();
//Remove last semi column
csv = csv.substring(0, csv.length() - SEPARATOR.length());
log.debug("Printing csv :-->>>>>>>>" + csv)
// def newPlanviewvalue = csv + ";" + planviewImpactedApp
// log.debug("Printing newPlanviewvalue :-->>>>>>>>" + newPlanviewvalue)
modifyValue(admin,PlanviewIssue,ImpactedAppField, csv)
else{
boolean modifyValue(ApplicationUser user, Issue issue, CustomField customField, String value){
IssueService issueService = ComponentAccessor.getComponent(IssueService);
IssueInputParameters issueInputParameters = issueService.newIssueInputParameters()
issueInputParameters.addCustomFieldValue(customField.id, value)
def update = issueService.validateUpdate(user, issue.getId(), issueInputParameters)
/* validate update info and execute update */
if (update.isValid()) {
IssueService.IssueResult status = issueService.update(user, update)
if (!status.isValid())
for (def error : status) {
} else {
} else {
return true
def String[] separateCSI(String apps){
def log = Logger.getLogger("com.onresolve.scriptrunner.runner.ScriptRunnerImpl")
//need to take out the [ ] that show up under my CSI's
apps = apps.trim()
log.warn(apps)
//if(apps.contains("\\[")) apps = apps.split("\\[")
def counter = 0
String[] result = apps.split(';')
result.each { String csi ->
if(csi.contains('[')){
String[] s = csi.split('\\[')
result[counter] = s[0].trim()
} else if(csi.contains('(')){
String[] s = csi.split('\\(')
} else if(csi.contains('-')){
String[] s = csi.split('\\-')
} else result[counter] = csi.trim()
counter++
//Change this line 10/15 from result to result.toUnique() to remove duplicates
return result.toUnique();
log.debug(""+epicIssue.key)
Regards
Manas
Ashkan Malekly
March 15, 2020
Hi @J Manas Kumar
Well i didn't read the whole of your content, but i suggest you setup automation for Jira plugin. And it is very flexible to write condition and validator and post-function. If you have it, i can guide you to accomplish your goal.
