how to change jira status by transition with REST API?
pillow
May 19, 2022
i tried to change status as a field,but not work,and i see we need to change the status by transition.
but i do't understand the schema .
for example,i want to transition my issue from to do to doing,how should i send the params?
Thiago Masutti
May 19, 2022
Hi @pillow
Welcome to the Atlassian Community.
Here's an example based on https://docs.atlassian.com/software/jira/docs/api/REST/8.20.1/#issue-doTransition .
See possible transitions:
GET <Jira-BaseURL>/rest/api/2/issue/<Issue-Key>/transitions
Transition an issue to a selected Workflow status (transition is made by ID and not name):
POST <Jira-BaseURL>/rest/api/2/issue/<Issue-Key>/transitions
   "transition": {
     "id": "21"
Thiago Masutti
pillow
May 19, 2022
i have read the doc,but i can't understand the schema.
what's the role of the parameters? what's the range of update,just comment?
and i can't find the transition id list. is it the actionId of every transition which declare in workflow?
Register here ⬇️
