Please suggest how to change time tracking settings for one project in jira using behaviour plugin because user want default as hour instead of minute for his project
please what is the script for this using behaviour plugin and advise me
Hi Nic,
Thanks for quick response
please if any do it for single project level using any script user want default hours instead of minutes
i am not familiar with scripting
Through script level or behaviour plugin is it possible?
please suggest
I don't have a way to do it either. And I can't recommend it because it will render your field inconsistent in behaviour - in some places it will default to h in others, m, for the same user in the same project. That is a really bad thing to do to your users - ask them to remember that sometimes you need to do things differently.
This is not something you can do with a behaviour.
Jira's default time settings are done internally, not on the front end. You might be able to inject something that can look at a number when it is entered and add an "h" if it is left blank, but it's only going to work in some places, which means your users are going to get an inconsistent and contradictory experience of entering time.
You have to choose a global default for all users really.
