how to configure JIRA installed in linux
Deleted user March 24, 2015
rrudnicki
March 25, 2015
As Nic mentioned, I agree that Puppet is a good way to do it. If I were you, a way to do it is:
Install JIRA in the standard way (by browser). Then, copy the main file configuration (server.xml, confluence.cfg.xml, database dump, etc) and create a script to automatize it on the next installation.
Renato Rudnicki
Nic Brough -Adaptavist-
March 25, 2015
You can do this with some automation tools (puppet for example), but to do it, you need to configure a working JIRA, work out which bits are "variable" (database connection, base url, Tomcat config to get it on the right url, proxy settings for web-server if you're using one, user directories, etc etc etc) and set up your preferred automation tool to be able to pre-prepare them.
I want to configure JIRA without using browser, is there any way to do if yes please let me know.
Norman Abramovitz
March 24, 2015
Is there a particular issue you are having?
