how to convert original estimate to number
Karim Belhadj
I have a formula that i must multiply a custom field number by the original estimate , i find problem because the original estimate have not the number type
so i need to convert it.
Regards
Nic Brough -Adaptavist-
December 28, 2018
The original estimate is not a "duration", it's a number.  Measured in milliseconds, so if you want it in minutes, you need to convert it with
issue.getOriginalEstimate() / 60,000
For hours, divide again by 60.  For days/weeks though, again divide, but remember to take into account your time tracking settings (1 day is 8 hours, not 24)
Note - that call above should return a long number if I remember right, but I think it's ok to multiply a long with a double?
Assia Touati
Hi, how to do the opposite of that calculation ?
I suppose that i have a number, and i want to put it in the original estimate field
June 12, 2020
How are you putting it in?  Code?  Typing?  REST call?
Assia Touati
using the smart values
{{#math}}{{issue.customField_10061}}+{{issue.customField_10062}}+{{issue.customField_10063}}+{{issue.customField_10079}}{{/math}}
it works when the sum is an integer, but doesnt when it's real
ex : 1 + 1 + 3 + 2   shows "1d" in the original estimate
or 1.5 + 1.5 + 2 + 1 shows 6h
but when i put 1.5 + 1 + 2 + 3 the rule doesnt execute
June 12, 2020
I don't use smart values, but that looks like a bug in it.
Assia Touati
I tried to use JSON,
here is my script
"fields": {
"timetracking": {
"originalEstimate": "issue.customField_10087"
where the customfield 10087 is a text field and i've entered as an example : "1h 30m" , but still doesnt work :s
June 15, 2020
Could you enter it in milliseconds, as that's the storage format?
Assia Touati
4.5 gives me this result when i do the conversion to milis
June 16, 2020
Ah, the API is not listening in milliseconds.  Have you tried plain 4.5?
Assia Touati
What do you mean by plain 4.5 ?
June 16, 2020
Literally feed it a number.  The rest API only takes numeric data (I thought it was milliseconds because that's what I see in code elsewhere).  4.5 is likely to be 4.5 hours, but you'll see that when you look again at the issue.  Whatever unit it is expecting, it will be consistent.
Assia Touati
when i add 0.5 to 4.5, it's working and showing 5hours, also if i add 2.5 to 4.5 it shows 1d (as i've set 1day=7hours in the Timetracking settings).
However, i want to have the 4.5 or whateaver (1.75 hours ...etc.) . But it's frustrating because it's not working!
Is it a bug ??? do i have to report it ?
Thank you again for you answers, fixing this problem will have an impact in our Jira projects.
Like • Luis Alejandro De Peña likes this
June 16, 2020
Are you saying decimal values are not working?
Assia Touati
Yes exactly.
June 16, 2020
That is very odd, it works for me.
I think, yes, you may need to report it as a bug.
Assia Touati
Could you send me a screenshot of how did you manage to make it works ???
Thank you
June 16, 2020
I'm not doing anything differently to you.  Hitting the rest endpoint with a curl backed json payload.
Assia Touati
I'm i doing something wrong in this code ???
"fields": {
"timetracking": {
"originalEstimate": "issue.customField_10061+issue.customField_10062+issue.customField_10063+issue.customField_10079"
June 16, 2020
Yes, you need to give it a number, not a string of custom field names.
Assia Touati
could you please give me an example ?
June 17, 2020
"fields": {
"timetracking": {
"originalEstimate": "4.5"}
Works for me.
Assia Touati
Me too,  but is there a way To parse the value of a cutom field.  ???
June 17, 2020
Yes, your code will need to ask Jira for the data for the fields, do the calculations you need and then send back a number.
Assia Touati
Ok, i'll try this, but do you have any documentation ? i'm not very familiar with JSON in JIRA, just starting.
azade bagheri January 23, 2021
Hello Assia,
can you solve this issues?
i need this feature and don't know how to configure it.
can you help me if resolved it?
thank's
Azadeh
Luis Alejandro De Peña May 19, 2021
I'm having the same issue ,,,, any help in this regard? When my custom field has a value of 4.5 it calculates as 45h! (number field and I pass the value as smart value with "h").
Thomas Wohlwend August 19, 2021
you may want to try 4,5
Jan Stähle
Is there any solution to the problem described above that entering 4.5 leads to 45h yet?
I am having the same issue when populating the field via Jira Automation with the following formula:
{{#=}}{{triggerissue.timeoriginalestimate}} * 0.85 / 3600 {{/}}
With the input parameter is 10h, I would expect to see 8.5h - what we get is 85h - when changing the 0.85 to a one digit decimal like 0.8 or 0.9 it gives me 8h, 9h respectively.
March 21, 2023
It's the same as given before.
Rajesh Ramankutty
Can you Give Some Example cant able to understand properly
Karim Belhadj
@Rajesh Ramankutty
my formula is
result = Original estimation * double(avp)
original estimation type is duration
avp is a custom field with type double.
Regards
Register today
