how to convert subtask to story
lipi September 5, 2016
This question is in reference to Atlassian Documentation: JIRA User's Guide
how to convert subtask to story?
8 votes
Damien (darwyn)
hi,
simply move your issue to the same project but choose the story issue type.
moving your issue can be done thanks to the 3 dots on the top right corner of your issue view and choose "Move".
cheers,
damien.
Bill_P
Tried Move - get a message:
"There are no other sub-task issue types associated with this project."
Bill_P
Turns out you have to switch to the Old View to see the option to "Convert to Issue".
Like # people like this
laurence
Thank you so much Bill! Saved my life! Is this new or we've just been blind? I guess I was always going to MOVE so maybe i missed it. Makes a world of a difference, thanks!
Like Phillip Terry likes this
Katja Angerstein
February 14, 2019
But soon everybody will be on the New View, how can we convert subtasks to issues after that?
Janek Bogucki
Kindly fix this so the 2019 view can be used to achieve this. This is not a minor oversight by any generous measure!
tobias.fielitz
3rd thread here I had to look at to get this working. Thx
Deleted user September 17, 2019
Its added to the new issue layout now..
Like R_ Schreurs likes this
mahdielmasaoudi
Thanks . Didn't know the existance of such option!
3 votes
naveen arroju
Hi matilda majed,
Sub-task issue -->view issue screen see more  options ---> select convert to issue.
mmartinezgb May 7, 2020
If you click the icon next to the ticket number you will find a dropdown menu where you can select the correct type.
Ivan Dretvic
October 28, 2019
productivity is reduced by constant design framework changes, and then not implementing features in the new design. This keeps happening with Atlassian.
Andreas Lianos
If you go to "all issues" view, and you filter what you want to change, there is an option now on the top right "..." menu that says "bulk change" (which of course you can use for a single issue as well).
Emiliano Vergara
December 9, 2019
Just pres dot "." and type "issue", in new version you can convert it right away!
Dare John Adesanya January 8, 2019
This is sort pain in the ASS.
Why not have Project - Project Version - Epic - Story - Task - Sub-task. I suppose this is the SCRUM structure. Atlassian made it this way in the previous version, but the new version seems to stupid. Who's the their new business analyst?
Nic Brough -Adaptavist-
January 8, 2019
Scrum is Epic -> Story -> (sub)task.  Jira is unlikely to change away from that, as that structure has been fundamental almost since it was first written.
Cedar Software Development Company
So you're saying Story represents Task sort of? But it would be great if there is Task for Story and Sub-task for Task. With this structure more details can be captured.
Thanks anyway.
January 26, 2019
No, a task is an issue type that you could have at the same level as a story or below as a sub-task level.  Or not at all if you choose not to have tasks.
Any issue at the story level can have sub-tasks of any type you define.
Dare John Adesanya February 7, 2019
Thanks for your explanation Nic
Matilda Majed February 27, 2017
I cannot find "convert sub-task to issue" only change parent..
February 27, 2017
Do you have "create issue" rights in that project?
If you do, and you still don't have the option to convert sub-tasks to issues, then you'll need to ask your administrators to revert whatever it is they have done to remove it.
genemerrill
April 13, 2018
Or maybe need to use "Move Issue" instead of "Edit Issue" in bulk change wizard?
Joshua McManus
There's a problem with the new Issue View that Atlassian released a little while back. You just have to switch back to the classic issue-view and you should see it in the "More Actions" menu.
Chaim Eliyah
October 19, 2018
Thanks to @Joshua McManus for that answer; that's the solution. Bulk edit didn't work. Checking permissions didn't work. They literally broke "Change Issue Type" in the new JIRA.
But we're used to things being broken with JIRA, so it's okay, right?
laurence
This new view is an absolute disaster, why take a good product and mangle it beyond recognition! It has so many issues, I am dreading the time when they'll remove the old view!
Like Katja Angerstein likes this
September 5, 2016
There will be a "convert sub-task to issue" option in the tools menu on the issue view (along with log work, attach, etc)
