Sign up Log in
how to create a JIRA issue from a Bitbucket repo?
Gunnar Wagner October 14, 2022
we use JIRA and Bitbucket on premise.
I see a mistake in some Packages build based on a Bitbucket repository. I have not clue reallz about the root cause of this problem.
So, to enable this to be worked on I need to create an issue in Jira linked tp that BitBucket repository. I can not see how though.
I have seen create issue from PR's, but I am not in a situation where I can create a PR. Actually I need to report a problem so that somebody (no matter who) can take care of this.
how can I achive this? Being used a little more to github or gitlab then Bitbucket I feel there is missing a "create issue" button somewhere in the repo.
Gunnar Wagner November 3, 2022
The silence on this implies it was not possible. If that is so, which would be hard to believe actually,  I do not really see (from a coding/git point af view) the point of Jira at all.
Or is my understanding basically wrong and Jira is not made for code development after all?
