how to create jira users for all persons in ldap?
Plexus ALM Support October 31, 2012
Is there a way to mass create users by pulling from ldap. We could certainly email out instructions on how to self-register, but if we could pre-register people it would be even better.
Harry Chan
October 31, 2012
Hi, can you explain what you are trying to achieve? Do you already have your users in LDAP? If so, you can simply get JIRA to use your LDAP directory as your user directory.
Joe Clark
October 31, 2012
Harry is right - JIRA can already do this automatically if you configure it right. The documentation is here: https://confluence.atlassian.com/display/JIRA/Connecting+to+an+LDAP+Directory
Septa Cahyadiputra
October 31, 2012
As describe on the other thread JIRA has the feature to set a "Default Group Membership" for LDAP users which basically will add any LDAP users into the default group when they login into JIRA successfully.
Hope it helps.
Septa Cahyadiputra
Plexus ALM Support November 8, 2012
We're already using "Default Group Membership", but we cannot figure out a method of having new users login other than creating the account for them
-Alex
