Hello All,
how to get all project id's associated to a particular screen using sql / groovy ?
Kiran
There is no easy answer for this, because there are two ways a project might be using a screen.
The first one is complex, but can be queried with a bit of work. The relationship is Project -> Issue type screen scheme -> screen scheme -> screen
The second one is harder to query. The relationship is Project -> workflow scheme -> workflow -> transition screen. Problem for SQL is that you will need to parse the workflow xml to find each screen that might be in use.
Because of this complexity, I doubt it's actually that useful to you. Could you explain why you are asking, rather than "how to do it"? What are you trying to achieve?
Hello @Jonnada Kiran
What do you mean by "associated to a particular screen", could you please elaborate a bit more.
