I'm using the following query to get the custom field values:
select *
from jira_app.CustomFieldValue cfv
join jira_app.CustomField CF on CF.Id = CFV.CustomField
join jira_app.jiraissue issue on issue.id = cfv.issue
join jira_app.project project on issue.PROJECT = project.id
where cf.ID = '101111'
Since epic link is also a custom field, I'm using the same query replacing the id of the CF with the Id of the epic link, it doesn't give any results.
How do I get the epic link for a Story?
Please advice.
Thanks.
Hi Veera,
This question has been answered in this similar post; Where are "Epic link" records stored in JiraDB?. The data is stored in the issuelink table.
I hope that this helps.
Best Regards,
Mogavenasan
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
