how to get properties issue using api java?
laumain jerome April 29, 2019
i would like to get the properties of issue with scriptrunner?
do you have an idea?
thanks
PD Sheehan
April 29, 2019
Assuming you mean non-field properties such as described here ...
Try to explore the IssuePropertyService
import com.atlassian.jira.bc.issue.properties.IssuePropertyService
def issuePropertyService = ComponentAccessor.getComponentOfType(IssuePropertyService.class)
issuePropertyService.getPropertiesKeys(null, issue.id).each{
log.info it.keys()
laumain jerome April 30, 2019
great! that exactly what i want! thanks a lot Peter-Dave
rashaveraka April 29, 2019
The majority of your interactions with issues using the Java API will occur with the Issue and IssueManager classes (and of course MutableIssue).
https://docs.atlassian.com/software/jira/docs/api/7.11.0/com/atlassian/jira/issue/Issue.html?_ga=2.69582098.367400705.1556550288-1439335163.1544544516
https://docs.atlassian.com/software/jira/docs/api/7.11.0/com/atlassian/jira/issue/IssueManager.html?_ga=2.69582098.367400705.1556550288-1439335163.1544544516
https://docs.atlassian.com/software/jira/docs/api/7.11.0/com/atlassian/jira/issue/MutableIssue.html?_ga=2.69582098.367400705.1556550288-1439335163.1544544516
So a simple Scriptrunner script that pulls a few issue properties might look like this (some things expanded for clarity that would otherwise be simplified in a real script):
import org.apache.log4j.Logger
import org.apache.log4j.Level
// Set logging level so we can see debug information
def log = Logger.getLogger("com.example.ListIssueProperties");
log.setLevel(Level.DEBUG);
// This is how we log information in Scriptrunner:
// log.debug("This will appear in Scriptrunner logs");
// Modify this to be the issue key you want to examine:
def issueKey = "PROJECTKEY-1";
// Get an instance of the Issue Manager
def issueManager = ComponentAccessor.getIssueManager();
// Get the issue you're interested in by issue key:
def issueObject = issueManager.getIssueObject(issueKey);
// We can now access the issue properties, as below:
def issueObjectPriority = issueObject.getPriority();
def issueObjectStatus = issueObject.getStatus();
// Output the issue status name and priority name to debug logging:
log.debug("Issue status: ${issueObject.getStatus().name}");
log.debug("Issue priority: ${issueObject.getPriority().name}");
return null;
thanks for your answer, but that's not what I'm looking for
Ben Poulson
April 29, 2019
What do you mean by properties? Field values?
properties of issue :) , see answer of Peter-Dave :)
