Hello to all,
I want to share Permission, so that everyone can change a filter (e.g. query change) and save it as the original one.
At the moment the filter is accessable (SharePermission set to GLOBAL) for everyone, but indeed only the owner can make changes on the original filter.
All other user only can change and save it as a copy.
Is there way to give writing permissions to all?
amend the core code
means you are definetly not able to give writing permissions to all by simply using the JIRA API 6.2.7?
Correct, because the ability would be a disaster for users, there's no code to provide it.
Today only! Share what you’re the most excited about for Team ‘25 or just dance out the beginning of a new quarter with us.
Comment the postOnline forums and learning are now in one easy-to-use experience.
