how to import more than 250 issues via csv at once ?
henri philakham July 4, 2019
trying to import a 1000 over issues and assign them to a specific resources at the same time, how do we do that ? in csv first before importing to JIRA
So its cloud then
Thanks Nir. I checked and I don't have this function in advanced settings, can I create it ? how do I do that ?
thanks
Ismael Jimoh
July 4, 2019
Are you on JIRA server or Cloud?
how do I check that my JIRA is a cloud or server instance ?
Nir Haimov
July 4, 2019
easiest way, if your Jira menu is on top you have server, if the menu is on the left you have cloud
Nir Haimov
July 4, 2019
Hi @henri philakham .
I did not understand the issue.
You don't how to import, or you tried and failed?
If failed, share us the steps you have done and the error you got.
If you don't know how to, here is an easy and clear guide:
https://confluence.atlassian.com/adminjiraserver/importing-data-from-csv-938847533.html
like I said I can only import 250 issues using csv method, I need to import like 1000 issues in my JIRA backlog and be able to have them all assigned at the same time during the import. Can you tell me how to do it ?
1- import 1000 issues into JIRA backlog
2- all issues are assigned to an assignee in CSV so that in JIRA they appear imported and assigned already during the csv import
thanks
Nir Haimov
July 4, 2019
Go to admin section -> System -> Advanced Settings
look for:
jira.bulk.create.max.issues.per.import
change it from 250 to what ever you want
Ulrika Eriksson
Is it also possible to change this on Cloud instances? Or is it another way how imports  works different in Cloud?
Could this change affect JIRA in a negative way? Performance? or other ?
JCFP Admin January 4, 2021
@Ulrika Eriksson
Not possible to change on cloud intance. There is a feature request at https://jira.atlassian.com/browse/JRACLOUD-67678
Like EKP likes this
Derek Wailes
It should be a bug rather than a feature. How are we expected to migrate projects with thousands of issues from CSV into JIRA Cloud with this sort of restriction?
Like # people like this
