×Hi Yassine,
You can reindex a single project by:
That should do the trick!
Cheers!
Hi Elisa,
What does a project re-indexing do exactly please?
Best,
Fadoua Boualem
re-indexing a single project - does that affects projects performance (accessing project while re-indexing)?
If we start two re-indexing simultaneously , Does it impact on JIRA performance?
Thanks in Advance.
re-indexing application simultaneously - not possible.; but re-indexing project can.
@Piyush_Annadate It is possible.
@Prashant Mali Depends on the amount of data those two projects would contain.
just updated my comments- thought about jira app re-indexing. I did re-indexing project with 3k, 9k and 1k - no issues for me with performance at any node.
Thanks for update...
Just to clarify here, this is not relevant for current JIRA as reindexing does not exist.
Hello YassineM, to re-index a specific project, you would navigate to the project in question, click on "Project Settings", and then click "Re-index project". You should then see a button that says "Start project re-index". Click on that button, and confirm you want to start the project re-index.
That should allow you to re-index that particular project. Please let me know if that helps!
