how to insert values into database table using jira plugin?
Nageswarara Rao
I m trying to insert values into mysql table using a jira plugin , in my plugin i wrote a java class and taken three fields and an insert button, my idea is to enter values into that fields , when i click insert button the values should be store in the table
how to do this ,
Thanks in advance
Henning Tietgens
May 7, 2013
You should use Active Objects for your purpose. See https://developer.atlassian.com/display/DOCS/Active+Objects
Henning
