I created a custom calculated date field and i need it to look at the issues created date and minus 7 days from that... how can id o this? i have tried this - return issue.getCreated() - 7
It's certainly possible, but first of all I wanted to ask, why?
If you're only going to use JQL, then you could achieve the same thing with
created > "-7d"
Also, issue.getCreated() is of type Timestamp, so you can't just subtract from it, since it doesn't know what you are subtracting... 7 minutes? 7 days? 7 years? You have to use some other method to subtract so that it knows.
Which add-on are you using for your field ? Script Runner, JIRA Misc Custom Fields, other ?
