×I want to call Rest API on clicking Web-item and I want to render the UI from the response.
Can I get some guidelines or examples?
Hello Navya,
It is possible to make a REST API call from a web interface, however, there will be customization required to make this possible. You will either need to create your interface with a PHP page or use javascript. An ideal resource to start with would be the developer basics which may be found at Integrating with Jira Software Cloud.
I hope this resource proves helpful and you’re able to find what you need.
Stephen Sifers
