Sign up Log in
how to make assignee field mandatory when text field is filled with text only
Prashant Mali April 14, 2018
I am trying to implement behavior script on text field. Can you please help me for script.
Alexey Matveev
April 14, 2018
Prashant Mali
April 18, 2018
I tried. but it may be different for assignee field.
I wrote server side behavior script on text field. and checked that text field is field is filled with text or not. once it get mandatory, unable to remove mandatory.
I guess setRequired is not working here.
Do you have a code to make mandatory field/optional field fields depends on text field value.
Prashant
Alexey Matveev
April 18, 2018
It would be better, if you produced your code. I do not have such code, it would take time to write it. It would be simpler to see your code and find problems with your code.
