how to make default assignee equal the reporter
Robert Matthews
One of my teams need to automatically assign incoming issues to the reporter of that issue. Does Jira 4.3.4 support this configuration for a single project?
Neal Applebaum
January 2, 2012
I think that would be pretty straightforward. Create a workflow with a post-function that sets assignee to reporter on issue creation, then assign the workflow to the project.
Robert Matthews
Thank you. As it is sometimes, you can get too close to the trees to see the forest.
JamieA
January 2, 2012
Additionally, I would remove the assignee from the create screen, to avoid confusing users.
Neal Applebaum
January 5, 2012
Certainly, one could create permissions such that a user has Create but not Assign permission (e.g. as in helpdesk use). Then, the Assignee would be hidden from the create screen for these users. it all depends on the use case.
Jeetesh October 20, 2018
Thanks Neal,
It works for me.
Jay
Thanks @Neal Applebaum you are a legend - obvious but sometimes need to be told :-D
Avdhesh Chauhan
January 9, 2012
I want to restrict a number custom field value to 5 digits
and i want taht only for a Number field and that will not affect to whole Jira number custom filesds .
How can i achieve this please let me know??
Neal Applebaum
January 9, 2012
Please create a new comment thread for your question. Again, you may need Javascript. Also, search the forum for similar posts.
Cheers
Neal Applebaum
January 8, 2012
Sorry, I can't help you write Javascript for that.
Avdhesh Chauhan
January 9, 2012
Ok Neal,
I Have one more issue.
and i want taht only for a Number field that will not affect to whole Jira.
Neal Applebaum
January 5, 2012
See above. If you mean you want the assignee to SHOW on the create screen and default from the Reporter, I don't know if that could be done. Maybe via Javascript.
Avdhesh Chauhan
January 8, 2012
Thanks for your quick responce Neal Applebaum
, you are right we can achieve that by Java Script but where can i find that code.
Please arrange the code for me.
Avdhesh Chauhan
January 8, 2012
Avdhesh Chauhan
January 5, 2012
i Want The value of assignee should automatically come in the create screen of the isasue and will be equal to Reporter.
How we can achieve this please help its urgent.
Avdhesh Chauhan
January 5, 2012
How we can achieve this please help its urgent??
Neal Applebaum
January 2, 2012
That sounds pretty straightforward. Create a workflow (or copy the one currently being used by that project) that has a post function on the create issue transition to set assignee to reporter. I'm using version 3.13, and even in that version there's an option "Assign to Reporter - Assigns the issue to the reporter".
