For example, I have project roles: Developers, Users.
I want to make my field read-only except on step "In Progress" for Developers, and except on step "Open" for Users.
As a result: ("In Progress" AND Developers) OR ("Open" AND Users).
Help, please :)
I am trying to make a text field read only on edit screen, but looks like the code is not working. can you please help with this -
jQuery(document).ready(function($) {
JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function(e,context) {
var projectName = AJS.$("#project-name-val").text();
console.log("RFC projectName "+projectName);
if (projectName == "RFC")
callReadonlyFunction();
function callReadonlyFunction(){
$('#edit-issue').click(function() {
console.log("Edit Button Clicked Start");
AJS.$("#customfield_13911").attr("readonly", true); //text field
console.log("Edit Button Clicked End");
In the console log, I do see messages but for some reason, the field is not becoming read-only.
the following script will run on edit screen
<script type="text/javascript"> jQuery(document).ready(function($) { JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e,context) { makeReadonly(); }); makeReadonly(); function makeReadonly(){ var editFunction=$('#edit-issue-submit').val(); if(editFunction === 'Update'){ var user=getCurrentUserName(); var statusText=$('#status-val').text(); var status=$.trim(statusText); var devlopersRoleID='10010';//changr the project role id here var usersRoleID='10011';//changr the project role id here $("#customfield_10571").attr("readonly", ''); $("#customfield_10572").attr("readonly", ''); if(isUserInGroup(user,devlopersRoleID) && status=='In Progress'){ //to make text field read only $("#customfield_10571").attr("readonly", true); }else if(isUserInGroup(user,usersRoleID) && status=='Open'){ //to make text field read only $("#customfield_10572").attr("readonly", true); } } } function getCurrentUserName() { var user; AJS.$.ajax({ url: "/rest/gadget/1.0/currentUser", type: 'get', dataType: 'json', async: false, success: function(data) { user = data.username; } }); return user; } function getUsers(roleID) { var users; AJS.$.ajax({ url: "/rest/api/2/project/TEST/role/"+roleID,//change project Key here(need to replace TEST with your project key) type: 'get', dataType: 'json', async: false, success: function(data) { users = data.actors.name; } }); return users; } function isUserInGroup(user, roleID){ var users = getUsers(roleID); for (i = 0; i < users.length; i++){ if (users[i].name == user){ return true; } } return false; } }); </script>
try with following code
//for dute field $("#duedate").attr("readonly", true); //to hide date picker icon $("#duedate-trigger").hide(); /to show date picker icon $("#duedate-trigger").show(); try with this for assignee field $("#assignee-field").attr("readonly", true);
check the REST API in isUserInGroup(user, roleID) function
small clarification!
do you want field read only on transition screen or view screen?
you can do it by using javascript? let me know if you want do it using JS so i can help you!!
Learn more
