how to replicate custom fields from one jira instance to another
Krithica G May 11, 2021
Hi ,
I want to replicate the custom fields in jira - A to Jira - B.
Can anyone please help how to do this?
Krithica
Daniel Armenta
Are there any other methods than using plugins?
Julie d_Antin _Elements_
Thanks for the mention @Daniel Armenta
@Krithica GIf you have already configured your Jira B, and want to create a remote copy of an issue (taking an issue from Jira A and copying it into Jira B), Elements Copy & Sync could indeed help.
If however, you are looking to take your Jira A custom field configurations and import them into Jira B in order to save time (not manually re-configuring all of them), Elements Copy & Sync will not be the right solution. I would recommend looking at Configuration Manager for Jira, or another migration app.
Jira B is already set up test instance. Most fields are same in JIRA A and B. Few are not available. Wanted to get those fields from Jira A to Jira B in simplest way possible. Kindly help.
Learn more
