how to resolve issues caused by Script runner hitting "c:/Program Files (x86)/Graphviz2.26.3/bin/dot.exe"?
Arnold Chang April 27, 2014
Here was the log associated with the problem I experienced. I'm running Jira 6.1.2 instance on Linux.
Apr 15, 2014 9:55:25 AM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet servlet-module-container-servlet threw exception
java.io.IOException: Cannot run program "c:/Program Files (x86)/Graphviz2.26.3/bin/dot.exe": error=2, No such file or directory
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1041)
	at java_lang_ProcessBuilder$start.call(Unknown Source)
And then we see the same thing on the 22nd:
Apr 22, 2014 2:04:14 AM org.apache.catalina.core.StandardWrapperValve invoke
	at com.onresolve.workflowreport.WorkflowReport.getDotProcess(WorkflowReport.groovy:141)
These seem to be caused by Groovy Runner running custom scripts which try and access non existing files. Is disabling Script Runner the only solution?
Can anyone provide advice? Thanks.
Arnold
JamieA
April 27, 2014
That's not script runner, it's the workflow report plugin. Looks lik it's misconfigured, but, you probably should just uninstall it as it's pretty much obsolete.
