how to restrict issue cloning per project in jira??
C_ Faysal
December 10, 2012
i've already set up permissions to only allow issue linking, which brings "is a cloner of / is cloned by" to developers role
so far so good.
the issue can still be cloned just by selecting "Clone" from the More Actions tab
this is really annoying cause some users here are way too lazy to create a new issue from scratch...they simply clone a resolved one...
8 votes
Dhananjay Kale
I have tried this in workflow step's properties -->
jira.permission.create.clone = denied
Its working for me without restricting sub-task creation (took ref from here)
roniz
Dhananjay Kale,
I want to deny cloning only in a specific project in jira. Is this possible in this way?
Dhananjay Kale
Yes. But need to make sure that workflow is not shared between the projects.
Like Sachin Nivrutti Pawar likes this
roniz
Yes- different workflow!
where should I define this sentence?
(jira.permission.create.clone = denied)
and where should I add the project's name?
roniz
where can I find the workflow steps properties?
Nic Brough -Adaptavist-
November 28, 2017
Edit the workflow, look at the status on the workflow, there is a properties panel
Like Dave Liao likes this
roniz
great- found it!
and should I put the "(jira.permission.create.clone = denied)"
in the Property key or in the Value key?
November 29, 2017
Both.  We use the = as a separator here because it's quicker than a screen shot and just as easy to explain.  The string on the left is the property, the one on the right, the value.
Like # people like this
roniz
thank you very very much!
I will try it!
Sayan Kaiser
Hi Nic,
I would like to deny clone for all groups and allow for few user groups is that possible as currently I can deny cloning for all users
thanks,
Sayan
Satheesh Kumar (Wipro)
May 19, 2021
is it possible to disable only the "Clone & Move" feature/option?
May 19, 2021
Yes, turn off or remove the "clone and move" app.
3 votes
Paul.Young
June 6, 2019
In current (cloud) Jira, the solution to block cloning for all is:
Property Key: jira.permission.createclone.denied
Property Value: true
Christian Mendez
November 27, 2019
This worked for me (2019).
Versicherungskammer Bayern
March 23, 2020
jira.permission.createclone.denied is the only key, that doesn't produce a stacktrace, other keys are working but with error in the log file.
You dont need a property value, the value for Jira is the last word in the key after the last point, implizit value is denied
key: jira.permission.createclone.denied
value: none
Dattatray Borude
March 25, 2014
Yes, DJ it worked for me too.
Jobin Kuruvilla [Adaptavist]
December 10, 2012
You can't disable just "cloning" by workflow properties because there is no separate permission for cloning. It looks for create permission.
December 10, 2012
You can't do it on a project by project basis unless you do some coding. i.e. add a condition to the respective web-item in system-issueoperations-plugin.xml.
Or maybe disable the system plugin and define an isue operation in your plugin along with the condition. You can make use of existing classes and jsp files.
C_ Faysal
December 10, 2012
hmm well.
so what is the best approach to restrict "Clone" from "More Actions" or can it be removed from there?
C_ Faysal
December 10, 2012
nice...i just disabled "View Issue Ops Bar Clone Link"
from system issue operations...
thats enough.
Thanks Jobin
Uday Kumar January 14, 2014
Hi Faysal,
Can you please give detailed steps on to disable View Issue Ops Bar Clone Link
Bob Swift
January 14, 2014
Hi Bob,
Thanks for quick reply. Looks like onDemand we can't disable clone function.
Bob Swift
January 15, 2014
That is an admin function, so only Atlassian can touch that for OnDemand.
Uday Kumar January 15, 2014
Hi Bob,
Can we disable this on local jira instance and without having plugin
Bob Swift
January 15, 2014
Yes, on a download instance, the administrator can disable the shipped clone operation following the instructions.You only need the plugin if you want to replace it with clone operations can be restricted or customized on a project by project basis if that is your need.
Bob, can you please point to instructions
Bob Swift
January 15, 2014
How to use clone properties for customization and there is a specific exampe of configuration for a project specific restriction
Sayan Kaiser
Hi Guys,
I am able to restrict cloning for all users, but I need to unrestrict for some groups. How will I be able to do that ?
Artsiom_Tverdakhleb April 15, 2019
jira.permission.create.clone.denied
Aaron Sterr October 30, 2014
We have similar issues with cloning In a couple of projects.  Users clone an issue, but then do not have edit permissions to modify key details.  We have good reasons for not granting edit permissions in those projects and we expect our users to "remember" that they should not clone in those projects.
I understand that clone would not be permitted if we remove the "create issues" permission, but we do want our users to be able to create new issues in those projects.
Would it be possible to make the "clone" action depend on both "create issues" and "edit issues" permissions?
That would solve most of our problem with regards to cloning.
Thank you,
Aaron
Dattatray Borude
March 25, 2014
DJ`s solution working... jira.permission.create.clone = denied
Dattatray Borude
March 25, 2014
Bob Swift
December 10, 2012
Sounds like you have an answer for your situation. For others, the Clone Plus Plugin for JIRA has a number of customization options which would allow restricting cloning to specific projects. More over, providing project specific clone options to fit better user needs. More info: How to customize
David Skreiner
November 8, 2016
No need for more expensive addons. Just adding the property jira.permission.create.clone.denied to every status in the workflow seems to do the trick just fine.
roniz
David Skreiner
Deepali Bagul
Hello @roniz,
Just add the properties jira.permission.create.clone = denied to the workflow/s of the specific project. Make sure the workflow is not share by other project. It worked for me.
Infrastructure
June 22, 2018
Does this still work ? I've try it on version 7.7, i've put the parameter everywhere on my workflow and it doesn't work ...
I've the same workflow as this ticket and the work arround doesn't work ...
https://jira.atlassian.com/browse/JRASERVER-62200
Saswata CHOWDHURY
September 19, 2018
Using properties can we restrict the Clone based on Roles. Say only admin should be able to clone and not others.
C_ Faysal
December 10, 2012
i tried setting some properties per issue state...
such as "jira.permission.clone=false" or "jira.permission.link=false"
no effect...
what am i missing?
