I know that it was discussed before, but I don't see any solution for this error :
{"message":"Client must be authenticated to access this resource.","status-code":401}%
I'm not working with UI ( User Interface) and I am working from backend, I want to authenticate myself (my users) to be able to run some API call.
I want to run this code :
curl --request GET \
--url 'https://MYSITE.atlassian.net/rest/api/3/applicationrole' \
--header 'Accept: application/json'
or in python :
import requests
import json
url = "https://MYSITE.atlassian.net/rest/api/3/applicationrole"
headers = {
"Accept": "application/json"
response = requests.request(
"GET",
url,
headers=headers
print(json.dumps(json.loads(response.text), sort_keys=True, indent=4, separators=(",", ": ")))
But I'm getting this error :
the question is how to authenticate it before or at same time (in same line) ?
Hi @Maziar Sojoudian ,
of course you are getting 401, there is no authentication header in your request.
I know you said username:password is not working anymore, but it does... so maybe you did something wrong.
Note that username:password need to be encoded in base64, so for example:
useradmin:passadmin = "dXNlcmFkbWluOnBhc3NhZG1pbg==" (and this is what you need to put in your authentication header).
You said you are working with python, so your request should be like that:
import requests
url = "https://MYSITE.atlassian.net/rest/api/latest/........."
payload = ""
headers = {
'Authorization': "Basic dXNlcmFkbWluOnBhc3NhZG1pbg=="
response = requests.request("GET", url, data=payload, headers=headers)
print(response.text)
I"m using the Basic authentication, but it looks like the response depends on the URL (i.e. the resource) I'm using..
Does anybody knows if I can use the same credentials I use to access Jira Service Desk or do I need to create a special user for API access?
Do I need to provide the user with special access privileges?
Does also the "expansion" of the JSON response depends on the user privileges?
Thomas
did you find the answer?
Hi Maziar
did you already have a look to the https://developer.atlassian.com/server/jira/platform/basic-authentication/
there is explained how to use Basic Auth etc.
curl -u username:password -X GET -H "Content-Type: application/json" http://localhost:8080/rest/api/2/issue/createmeta
Cheers
Kurt
Either you use username:password and if that does not work you can use a token based approach
https://confluence.atlassian.com/cloud/api-tokens-938839638.html
see also the answer from Nir
Cheers
Kurt
