how to two issue type inner join on eazybi
JinSeok, Heo June 27, 2016
I want two issue type innner join
how to join to issue type?
image2016-6-28 14:6:17.png
Martins Vanags_eazyBI
"Issue type" dimension is imported in eazyBI based on issue types used for imported issues.
You could create scripted custom text field (using some JIRA plugin: JIRA Misc or ScriptRunner) that returns joined issue types as a comma separated string, and then import this custom field into eazyBI as a custom dimension. Here are some examples of JIRA Misc precalculated custom fields: https://docs.eazybi.com/display/EAZYBIJIRA/JIRA+Misc+Custom+Fields
To import precalculated custom field in eazyBI, you should add advanced settings for this field. You could find how to define advanced settings in our documentation: https://docs.eazybi.com/display/EAZYBIJIRA/Advanced+settings+for+custom+fields
If it is not the case or your need further assistance with importing this custom field please share more details of this request to support@eazybi.com
Martins Vanags
