How to use the let's encrypt with JIRA for HTTPS certificate?
A detailed instruction on how to use this is documented here by @Ivan Tichý.
http://blog.ivantichy.cz/blogpost/view/74
This doesn't work if you're using nginx subdomain via reverse proxy. Isn't it still connecting to the service using http like before?
But this doesn't work if you're using Nginx as the webserver. I have reverse proxy set up for jira, and now the whole thing is hosed. At least http was working.
