I am trying to create issue from my website but im stuck in writing a Javascript which connect to the API , and i can not find any example in jira documents, its all in console or node language. can anyone put a javascript sample code for issue creation ? im actaully mostly stuck with the basic authentication and also to MAKE the fields in the form in my website and equal them with the jira fields
Have you tried to use an issue collector? If this isn't enough then you could also check out some questions about this topic which have already been discussed here.
