×//how to wait for indexing to be complete?
IssueIndexingService indexService = ComponentAccessor.getComponent(IssueIndexingService)
long reindexTime = indexService.reIndexAll()
#after reindex has finished run a JQL query
@Beppe MarconI don't get you , once you trigger(background or fore ground indexing) you need to wait, and you waiting depends on how large is your instance. therefore what do you want to achieve here ?
Best!
my JQL isn't able to find certain link types between issues which have been created in the same Groovy postfunction running the JQL. I want to reindex at a certain point of the postfunction and run the JQL only after reindex has completed in order for the JQL to find all nodes and link types present.
How do I poll for completion and only after completion continue with my groovy postfunction?
In a post-function, you probably only want to re-index the current issue, or possibly a small set of issues that have a relationship with it (for example, as you suggest, all linked issues).
If you are indexing a small set of issues in the post-function, then you don't need to wait - the indexing for each is complete before it does the next step in the function.
Reindexing single issue doesn't update links, I've tried the following:
boolean wasIndexing = ImportUtils.isIndexIssues()
ImportUtils.setIndexIssues(true)
IssueIndexManager indexManager = ComponentAccessor.getComponent(IssueIndexManager)
indexManager.reIndex(issue)
ImportUtils.setIndexIssues(wasIndexing)
still the JQL run after the above returns empty result, the same JQL in a separate postfunction returns correct results.
