working on building desktop app using angular 4 and electron and try to get authentication token for jira but i am getting back status code: 500, any help to get around this issue. i believe it is cors issue :
here is request headers:
return message from server:
{"message":"Expected authority at index 7: file://","status-code":500,"stack-trace":
"java.lang.IllegalArgumentException: Expected authority at index 7: file:// ...etc
this.http.post('https://somecompany.atlassian.net/rest/auth/1/session' , body)
.subscribe(d => {
console.log(d);
this.router.navigate(['/home']);
error => {
console.log('errororororororor');
console.log(error);
You need to add headers on a proxy service using reverse proxy like nginx. I use docker to test with a reverse proxy service to add cross origin headers. Otherwise Jira doesn't allow it. At least not in Jira Cloud REST API. If you use Jira Server I believe you can whitelist apps through config/settings. The issue is actually browser side and you can use chrome plugin to disable the check but that's not advisable.
Help us plant more trees
