import cucumber json in Xray jira -;error: Error assembling issue data: project is required
Hari Venkadesh August 23, 2024 edited
Hello there,
 I'm trying to import cucumber json to Jira (X-ray), but I'm facing few difficulties. I've included the specifics below.
I have tried two api's of both 1.0 and 2.0 versions, according to below documentation
https://docs.getxray.app/display/XRAY30/Import+Execution+Results+-+REST#ImportExecutionResultsREST-CucumberJSONresultsMultipart
https://docs.getxray.app/display/XRAY/Import+Execution+Results+-+REST
POST /rest/raven/2.0/import/execution/cucumber/multipart?testExecKey= HTTP/1.1 Authorization: Bearer xxxxxxJ Content-Type: multipart/form-data; boundary=--011000010111000001101001 Host:ontent-Length: 405 -----011000010111000001101001 Content-Disposition: form-data; name="result" C:\Users\z040609\Downloads\bdd_report-master\bdd_report-master\POC\POC\cucumber-json\LockStatus.json -----011000010111000001101001 Content-Disposition: form-data; name="info" C:\Users\z040609\Downloads\bdd_report-master\bdd_report-master\POC\POC\cucumber-json\testExecutionInfo2.json -----011000010111000001101001-
I'm receiving this response"error": "Error assembling issue data: project is required" while hitting above api's.
info:
{ "fields": { "project": { "id": "value" }, "summary": "Test Execution for cucumber Execution", "issuetype": { "id": "10212" } } }
Florian Bonniec
Hi @Hari Venkadesh
You are setting the project key instead the project id in "project": { "id": "IRX67017" } no ?
Regards
Hari Venkadesh August 26, 2024
Hi @Florian Bonniec , Thanks you, Now I can able to create test execution
Like Florian Bonniec likes this
Florian Bonniec
Feel free to approve the answer if it fixed your issue.
