import/export from one Jira to another Jira
Snehal Jadhav May 27, 2024
whenever I try to import the Jira data from A instance to B instance its vanish the previous data from that B Jira instance and only a instance data get imported into it.But i want B Jira data as well as A Jira instance data in B instance.
Tushar Gohel
Hi @Snehal Jadhav
Here is the document to import the Jira data from one instance to another. Please make sure you need to do this project by project.
If you try to import the whole backup it will overwrite your existing data.
https://confluence.atlassian.com/adminjiraserver/restoring-a-project-from-backup-938847691.html
Tushar
