×Hi,
I've read: http://confluence.atlassian.com/display/JIRA/Importing+Data+from+CSV
But I don't really want to import my data from the other system. I want to start fresh and clean. Can you help me understand how to import the users I had in the other system? Is that possible?
JIRA Command Line Interface has support for adding users in a couple of ways. Also, there is a snapshot available for JCLI-251 that can be used to create the add user import script.
You should be able to add users through a jelly script.
http://confluence.atlassian.com/display/JIRA/Jelly+Tags
You need to use create user tag
http://confluence.atlassian.com/display/JIRA/Jelly+Tags#JellyTags-jiraCreateUser
and add user to group tag
http://confluence.atlassian.com/display/JIRA/Jelly+Tags#JellyTags-jiraAddUserToGroup
These are links to Jira 5.0 documentation. If you have an earlier version of Jira, please check that documentation since the Jelly interface changed sometime during the 4.X releases.
