I'm just trying to configue jira to send notifications to a confluence workbox.
My actual problem is, that jira-activities like (issues assigned to a user) are not displayed in the confluence workbox of a given user.
The docu says the following standard plugin should be installed and activated in JIRA (JIRA 5.2 or higher)
Though, I can't find them nor install them from the plugin-manager. I neither find any information about a change in that config process in the release notes nor JIRA- or Confluence-docu. Did anything change?
Are they maybe missing or what could be my misstake when trying to connect JIRA and Confluence?
Thank in advance!
florian
The addons you are looking for is called
WorkBox - Common Plugin
It was changed in JIRA 5.2
You need to ensure that JIRA and Confluence can fully connect to each other, it is there very important that application-link is setup between to two instance.
