Can i copy object types from one object schema to another ?
You can copy the object type in the same Object Schema only. You need to export to CSV and import to another Object Schema.
(Another useful feature is creating a copy of the Object Schema.)
FYI
Hakan Bahadir
Solutions Engineer
You could also setup an Insight object schema import in the target object schema. In this way it is easy to copy all the objects and not only the structure to the new schema.
Björn
